help with skewnesses
Old   September 1, 2007, 05:45
Default help with skewnesses
rosol
Hi
Can any one tell me what is the meaning of skewnesses because when I mesh the triangular 3D channel the edges and faces meshs ok but the volume is don't mesh and the fluent display an error message about the skewness.
I will appriciat any response
Old   September 1, 2007, 07:48
Default Re: help with skewnesses
Jianfeng Zou
You should carefully set the mesh parameters on all geomerical faces.
Old   September 2, 2007, 05:38
zeboudj
Dear, skew or skewsness is statistical word, when you plot a gauss distribution of any variable, you can perform the skewness od the curve and it has a meaning to distingu between 2 distribution.
Old   September 3, 2007, 14:46
rosol
Dear Zeboudj,
Thank you very much for your answer and effort.But when can I find the value of skewness in fluent or how can I change its value.please help me to resolve my problem to mesh the 3D triangular channel with dimensions in microns. with thanks
Old   September 9, 2007, 00:46
Diego Flores
It's easy, so tell me, what is your software to mesh????
Diego from mexico
Old   September 9, 2007, 11:24
rosol
Dear Diego
My software is gambit to mesh and fluent 6.3 to solve I hope to get help from you
Thank you
Check the skewnesses of your face meshes and make sure the face mesh sizes are not to sophie-l Main CFD Forum 1 April 13, 2009 20:16
Check the skewnesses of your face meshes and make sure the face mesh sizes are not to sophie-l ANSYS Meshing & Geometry 0 April 13, 2009 18:27
