simulate a turbulence mixing flow
Old   August 30, 2007, 07:08
Default simulate a turbulence mixing flow
arya
I am having problem with my residual. It keeps fluctuating. The physics of the burner starts with diffuser, a mixing chamber, inside of this mixing chamber there are pipe with holes to inject the gaseous fuel into the mixing chamber. The mixing chamber is having a rectangular cross section. Then the mixing goes into flame holder consist of 7 and 16 slots (I have 2 cases) and into the combustor.
Until now I haven't started my combustion simulation, because my cold flow simulation has a very bad residuals.
Is there anyone can help me to solve this thing?
Thanks
Arya
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 12:42
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
How to define the turbulence intensity and mixing length at an outlet (for k-eps)? david39 OpenFOAM Running, Solving & CFD 6 February 2, 2011 04:01
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 18:15
Turbulence in pipe flow. JM Main CFD Forum 3 February 2, 2007 09:18
