Evaporation of water... help needed!!
Old   August 30, 2007, 04:51
Default Evaporation of water... help needed!!
Arpit
Dear all,
I am stuck with the following problem: I have a 2d slab filled with water and i m supplying a constant heat flux at one of its edge. As heat penetrates inside, the water should evaporate and get converted to vapor. I define it as a multiphase model and use the UDF DEFINE_HET_RXN_RATE {http://www.fluentusers.com/fluent6326/doc/ori/html/udf/node56.htm}
I have tried using VOF/mixture models as they suit my purpose. I define phase I as air+water vapor(primary phase) and phase II as water liquid. In the interation panel ...I define a reaction phase 2 (water liquid)----->phase1 water vapor.
When i define the reaction rate function as none..it does not solve for the species balance. When i give that as population balance (as no other option is available) it gives the error:
Error: > (greater-than) : invalid argument [2]: wrong type [not a number] Error Object: nan
I don't know what to do..I have looked at all previous discussion regarding evaporation on the forum but can't get how to simulate this. I would appreciate any help in this.
Thanks a lot!!! _________________ Regards, Arpit
Old   September 10, 2007, 11:00
Default Re: Evaporation of water... help needed!!
rachit
Dear arpit , i am also very much interested to find out the solution of this very general problrm and like u i also tried a lot to find out the suitable model for same , unfortunately able to find the same in fluent.
i will be very thankful to all users on this forum to help me in this regard.
rachit
Old   September 10, 2007, 11:04
rachit
Dear arpit , i am also very much interested to find out the solution of this very general problrm and like u i also tried a lot to find out the suitable model for same , unfortunately i also failed to find the same in fluent.
rachit
How to simulate the process of water evaporation by UDF? qiyang860908 Fluent UDF and Scheme Programming 10 January 9, 2015 14:59
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Water Evaporation and condensation modeling Linjie FLUENT 3 February 6, 2012 14:08
Water Evaporation and condensation modeling Linjie CFX 6 May 24, 2007 15:55
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
