August 29, 2007, 14:11 |
Fluent Dynamic Meshing
I am trying to model the water-entry phase of a thin triangular wedge. The way I have created the grid is to divide the flow domain into two fluid zones called "fluid" and "moving_fluid". The "moving_fluid" zone is a small zone adjacent to the wedge, while the "fluid" zone comprises the rest of the domain. Both the "moving_fluid" and "fluid" zones are meshed using the triangular pave method.
I specify the RIGID-BODY movement of the "wedge (wall)" and the "moving_fluid" zone using a udf while defining the dynamic mesh zones in Fluent. I also enable remeshing and smoothing of the mesh. Even though I have specified that the "moving_fluid" zone moves as a rigid body, while previewing the mesh-motion I see that that triangular mesh within this zone gets smoothed on remeshing. Fluent manual does mention that if the zone is meshed using a QUAD scheme it is not smoothed. I was wondering if there is a way to selectively tag a zone with triangular elements to prevent smoothing. Thanks in advance for the help. Vimal |
Dynamic meshing of impeller using fluent | shadyenany | FLUENT | 6 | September 22, 2011 17:56 |
Dynamic mesh in Fluent to study tire in contact with road surface | lihuang | FLUENT | 10 | March 8, 2011 11:21 |
Dynamic Meshing Literature | oxidising agent | ANSYS Meshing & Geometry | 3 | November 20, 2009 15:58 |
dynamic meshing option | arehman | Main CFD Forum | 4 | June 27, 2004 03:55 |
Dynamic Meshing | James | FLUENT | 0 | May 31, 2004 08:27 |
