August 29, 2007, 03:35 |
how to open gambit and fluent in ubnutu
Hi, I am having ubnutu. We have gambit and fluent in the central computing facility. We used to open them using exceed in windows. Now i would like to know how to open then in ubnutu. I am getting the following error.
"unable to open display" Canany body help me out. Thandavan |
August 29, 2007, 04:22 |
Re: how to open gambit and fluent in ubnutu
Set the DISPLAY environment variable correctly ... ask your local linux system admin to assist.
August 30, 2007, 01:24 |
Do you log in into another computer? Do you do this then via telnet or ssh?
Try ssh -X [host]. Big X pls, then I think you can start your software, without any problems. Good luck, MA |
August 30, 2007, 05:30 |
Hi I tried , ssh -X still i am getting the same error.
I set env variable as export DISPLAY=10.93.202.52:0.0 is this correct. Thanks Thandavan |
August 30, 2007, 07:44 |
Are you sure, that you used an upper-case X?
check the man-page for ssh: man ssh Then you needn't set the env variable any more. But maybe the ssh-server is not configured for this. Anyway, there is no mistake to set the variable, I guess, and the way you do it, is correct. But be sure, that the IP-Ad you type in is that of your own computer, and not the host's. To find out your own IP (on your computer): /sbin/ifconfig to find out your screen-id (on your own computer): echo $DISPLAY this should be working then. Good luck! MAAAA |
August 31, 2007, 12:16 |
Try this in a terminal:
fluent 2ddp -driver x11 or gambit -driver x11 |
September 3, 2007, 06:18 |
I tried as u said. I read SSH man. it was said that one should not set the display variable. I did not set it then. I used upper case X. Still it is saying "Unable to open display" Please help me. Thank you |
Converting Fluent mesh files to Gambit neutral files | samuelkc | ANSYS Meshing & Geometry | 9 | April 21, 2021 07:28 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 | pdilly | FLUENT | 23 | April 2, 2016 13:10 |
help for opening gambit file n Fluent..... | rizwan | FLUENT | 1 | March 22, 2009 23:41 |
Facing Few Problems in Fluent and Gambit | Ravi Duggirala | FLUENT | 5 | March 11, 2006 04:13 |
