August 27, 2007, 09:32 |
importing from Solid Works
I am having trouble importing my solid works file. I have been successful doing this with older versions of Gambit, but v2.4 keeps telling me either a) 0 faces, 0 edges, 0 vertex have been imported or b)translation requires license feature geom-trans. Is it possible that the university's license file doesn't allow Solid Works importing? I have tried ACIS, Parasolid, IGES, Step files with no luck. Any suggestions would be appreciated.
thanks |
August 27, 2007, 10:03 |
Re: importing from Solid Works
Hi, I have been using STEP files successfully, generated on my PC by the solidworks 2005 available on emule...
August 28, 2007, 13:22 |
do you have to declare the flow volume in Solid Works? I can import the 3d drawing, but I can't seem to define the flow volume.
Have you tried using the solid works ad-on made by Fluent? I am having trouble with that as well. thanks |
August 28, 2007, 13:58 |
I just imported the geometry on a step file into gambit. to continue with the meshing process there. Unfortunately I did not use anything else. Sorry.
Basic advice on Importing Solid Edge model to CFX needed. | stephen__white | CFX | 1 | February 9, 2011 18:40 |
Importing from Solid Works | mettler | FLUENT | 1 | March 5, 2005 23:45 |
Get Free Geometry File -Solid Works | Joe Brian | Main CFD Forum | 0 | December 16, 2004 23:25 |
Importing of Solid files in PROSTAR or PROAM | jafar | Siemens | 1 | November 26, 2001 09:20 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
