Support on Vista??
Old   August 27, 2007, 05:25
Default Support on Vista??
david
Have anyone trying to run Gambit 2.2 and Fluent 6.2 on Vista operating system??? Cause if it can be used, then i plan to change my XP operating system to Vista operating system. Thanks.
Old   August 27, 2007, 05:40
Default Re: Support on Vista??
david
Sorry, i want to add something here. Currently, I use Exceed 7.1, Gambit 2.2 and Fluent 6.2 and I want to change to Vista Ultimate, so will it works on Vista Ultimate?
Old   August 27, 2007, 08:18
Ressel
Keep the Windows XP ! Ansys are working hard to adapt to Windows Vista. But I figure that it will come in 2008,if Microsoft team give a hand on it...
Old   August 27, 2007, 12:48
sina
I tried with Exceed 7.0 , Gambit 2, and Fluent 6.2 and got that only Fluent could be run on Vista. also dont forget that you will have less Memory available for simulation on Vista campared to XP.
Old   August 27, 2007, 14:54
Ressel
I didn't test... but Fluent could run in Vista in serial simulations. I'm not sure if it will run in paralel cases.
Old   September 7, 2007, 00:59
Nantaratn Kananai
My clue use could not use Gambit in Vista. Exceed couldn't run in Vista cause Gambit mal-function. Anybody can tell me, how to fix it ? Thanks
Old   September 7, 2007, 01:19
Nantaratn Kananai
Good News !!!!
The problem of Exceed is just a Vista security. There is a small picture if shield in ICON. Just change the security of that file. Then, Exceed can run properly.
Old   September 13, 2007, 00:37
david
Can Nantaratn Kananai explain steps on changing the security of the file? Cause i'm a bit confusing on it and i'm still new with Vista.
Thx in advance
How to define support condtion of side of plate? colopolo CFX 0 September 28, 2011 22:48
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
can window VIsta support Gambit and Fluent? fadhil FLUENT 5 June 19, 2008 17:52
