how to report mass flow rate at line-surf
Old   August 24, 2007, 06:16
Default how to report mass flow rate at line-surf
suman kandula
friends,
can any one help me out, how to report mass flow rate at surface/line-rake, other than boundary. generally we find mass flow rate through report/fluxes option, where we can select boundaries. but, my doubt is about how to find report flux at a line-surf
bye suman
Old   August 24, 2007, 09:41
Default Re: how to report mass flow rate at line-surf
Joe
Create surfaces where you want the mass flow value. Access the newly created surface in report/fluxes.
Old   August 24, 2007, 21:30
AAA
Hi
You can not find the mass flow rate through a rake, since it is nothing but some points with no area for the flow to cross. You have to use a surface for that. Create one where you need to find the flow rate.
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Mass Flow Rate is not converging destgir448 CFX 5 December 11, 2010 06:55
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 10:29
mass flow rate error Masood FLUENT 0 May 22, 2005 01:32
