Saving XYPlot or other data in unsteady simulation |
August 23, 2007, 13:51 |
Hi all, I simulate a special concentric duct and try to get the temperature or also other profiles along the surface with time. Is there a possibility to generate a table with T(x,t). Or in another way, how can I save data, apart from pictures and *.dat files for every time step (-%t)?
Thanks a lot for your help franz |
August 23, 2007, 20:53 |
Re: Saving XYPlot or other data in unsteady simula
solve > monitors > surface
August 24, 2007, 04:18 |
Thanks for the hint. I know how to use the surface panel, you only can store average values. I like to store a vector of x (location) and T (temperature) over time so I can show the temperature behavior with time and location. At the end I want to ceat a 3D plot with T(x,t). Does anybody know how to do this in an easy way, perhaps there is somewhere a botton I didn't see until now. Or do I have to write a UDF?
August 24, 2007, 09:36 |
Read the transient case files into a proper post-processor e.g. Fieldview or use a UDF. You can even directly read from the dat files using Matlab.
Drawing 2D foil data from 3D simulation | f0208secretx | FLUENT | 2 | April 13, 2011 04:47 |
unsteady data averaging | paragnsk | FLUENT | 0 | November 13, 2010 14:42 |
Getting Time Series data from saved unsteady data | Atul | FLUENT | 4 | November 26, 2008 06:12 |
Using previous data for starting a new simulation | siw | FLUENT | 2 | October 24, 2008 18:58 |
Turbine flow simulation data | Mohan Varma | Main CFD Forum | 3 | October 18, 1999 10:27 |
