Meshing of 3d wing and fuselage
Old   August 21, 2007, 11:26
Default Meshing of 3d wing and fuselage
yasir
Plz let me know how to easily mesh these componets attached togather
Old   August 23, 2007, 18:52
Default Re: Meshing of 3d wing and fuselage
Carlos
It is very difficult to comment without seeing it. However, I would use an unstructured fine surface mesh on the fuselage and wing, then a coarse spacing on external boundaries of your solution domain. Now use a volume mesh to fill the gaps. Meshing takes lots of practice so have a play around with it.
Regards,
Carlos.
Old   August 26, 2007, 11:50
Default volume mesh of sphere of dia 2 m
yasir
i m meshing the sphere using Tgrid. will it give me good and accurate result plz if any ine could suggest me a better technique
thank you
ur help is always appreciable
M6 ONERA Wing profile Cyril A. Main CFD Forum 18 December 31, 2016 15:59
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Dealing with Singularity..! JOKER ANSYS Meshing & Geometry 15 November 10, 2010 08:57
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 12:22
3D wing study Bridou FLUENT 5 July 22, 2007 20:03
