dynamic mesh on a hexa grid
Old   August 21, 2007, 08:42
Default dynamic mesh on a hexa grid
Manoj Kumar
Hi Everyone
I am trying to simulate motion of a ship using dynamic mesh feature. The domain has been discretized using hexa mesh.
Mesh smoothness on all shapes have been activated using following text command-
/define/models/dynamic-mesh-controls/smoothing-parameter/spring-on-all-shapes?yes
The problem I am facing is that, the above text command doesn't takes care of mesh smoothness on the plane of symmetry, though it ensures smooth internal volume mesh.
Mesh on the plane of symmetry : http://img406.imageshack.us/my.php?i...ymmetrypj8.png
Mesh on an internal plane parallel to the plane of symmetry: http://img515.imageshack.us/my.php?i...nteriorbp9.png
Please help.
Thanks,
Manoj
Old   August 23, 2007, 02:42
Default Re: dynamic mesh on a hexa grid
mAx
i wouln't work with smooth. Thus you have an hex grid, so I would use the layering feature. it is quite simple.
Old   August 23, 2007, 09:08
Manoj Kumar
In my case the moving grid is translating as well as rotating. How do I implement layering feature.
Old   August 24, 2007, 02:18
mAx
the layering feature is available under define/dynamic mesh/parameters enable the layering option under mesh method.
for the rotatition motion, I don't know exactly how is exactly your geometry, but I assume you can work with sliding mesh
Old   August 8, 2010, 09:28
Default How to activate"spring-all-shapes"?
ahmad
almostafa67 is on a distinguished road
hi dear all...
i faced an error message,negative cell volume detected,i think if i activate spring-on-all shapes this error does show again,but i do not know hoe to activate it in ansys 12.0,
any help will be appreciated...
almostafa67 is offline   Reply With Quote
[ICEM] export hexa mesh to fluent Wieland ANSYS Meshing & Geometry 37 January 23, 2013 04:27
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 16:40
grid partition AND dynamic mesh adaptation !!!!!!! bohis FLUENT 0 January 16, 2009 04:00
[Other] How to mesh the 1st grid point lakeat OpenFOAM Meshing & Mesh Conversion 1 October 8, 2007 08:13
