How to evaluate length scale for a pipe flow
Old   August 18, 2007, 10:24
Default How to evaluate length scale for a pipe flow
kb
Hi I want to use the turbulence intensity and length scale in my turbulence specification method but I do not know how to estimate the length scale value? knowing that I have a 3D pipe with diameter 0.0985 m?
Regards Kb
Old   August 19, 2007, 15:06
Default Re: How to evaluate length scale for a pipe flow
AAA
Hi
The length scale is usually the length of the opening, which is the diameter in your case.
Old   August 21, 2007, 08:49
kb
Hi AAA thanks to the reply. If it the diameter what you think should I multiply it then by 0.07 or no? I saw in the manual that length scale=0.07 * l? what you say?
Old   August 21, 2007, 14:14
AAA
Hi
You are right (I was wrong!). Since you have a pipe flow, the turbulence length scale is the pipe diameter multiplied by 0.07.
Regards
AAA
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
Turbulent Characteristic Length/Turbulent Length Scale fluentnoob FLUENT 2 July 3, 2009 09:40
Length Scale vs. Hydraulic Diameter? Will FLUENT 1 April 13, 2004 07:09
Turbulence length scale in pipe flow lei Main CFD Forum 0 September 26, 2002 05:07
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
