setting time step size!
Old   August 14, 2007, 06:12
Default setting time step size!
raja
hi all! i am a learner of CFD,
could somebody please explain me if there is a standard procedure to follow to set the time step? or is it different for different types of flows such as paraboloc and hyperbolic? thanks in advance....raja
Old   August 14, 2007, 08:11
Default Re: setting time step size!
test
Raja,
You could get an estimate of time step required for your model using the following simple concept-->
Approximately calculate the residence time of the fluid in the domain (eg. if you have inlet velocity of 0.1 m/s and length of domain is 1m, ~residence time = 10 s) usually can be put as (smallest length/velocity scales in the simulation)
For cold flow case --> time step could be 1/3 to 1/4 of residence time.
Reactive flow --> 1/10 of residence time. time step may need to be less than reaction timescale during start of calculation. The time step could be slowly increased as calculations proceed.
Turbo-machinery --> 1/w
Buoyancy driven flows --> max time scales which could be used
sqrt (L/g B * temp diff)
B--> coeff of thermal expansivity L--> length scales associated with vertical temp gradient g--> acceleration due to gravity
Use 1/3 to 1/5 of this value calculated
Best luck
Old   August 14, 2007, 09:31
raja
thank you very much!i got it clear now!
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Time step size, number of time steps and max iterations per time step guido_88 FLUENT 4 August 30, 2012 15:49
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 11:23
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
