Why Contours not display in turb. flow over Cyl.?
Old   August 12, 2007, 08:23
Default Why Contours not display in turb. flow over Cyl.?
Mahbub
Hi to all,
I am trying to model turbulent flow over cylinder at Re= 3900 in 2D. I found good drag coefficient (0.9) but the contours of stream function or velocity or pressure doesn't demonstrated the vortex shedding in the wake. For your information, I give the parameters used: 2D-unsteady-seregeted solver, K-ebsilon turbulence model, enhanced wall treatment, PISO, time step size=.01, max iter. per time step=20,BC-Velocity inlet-periodic-wall-pressure outlet etc. What's the wrong with me? Please help me if you have any experience.
Mahbub
Old   August 12, 2007, 09:46
Default Re: Why Contours not display in turb. flow over Cy
Joe
Could be any number of things...
ke often over predicts the turbulent viscosity.
You have to systematically evaluate all possible sources of disagreement.
Old   August 12, 2007, 12:10
farhan
try K-epsilon realizable model
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
contours display in post process askriitr FLUENT 0 July 1, 2009 11:55
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
