Hi all,
I am modelling a flow over bluff body and using an unsteady k-e model. In the literature, I found that when using unsteady solver, the force monitors i.e. lift and drag force will fluctuate like a sine function and we can get the average or max of that. I did not get the fluctuation in drag and lift coeficients. All I got is the same as steady solver where the coefficients will converge at one particular value. Is there something wrong here? I hope someone can clarify. Thanks, Sham. |
Than may be your problem is not a unsteady one.
how to predict unsteady flow from case definition? | Felix | Main CFD Forum | 6 | August 28, 2007 16:40 |
Unsteady flow in FLUENT | Vidya Raja | FLUENT | 2 | November 2, 2005 16:29 |
Unsteady Boundary Layer Flow | Wen Long | Main CFD Forum | 0 | July 29, 2002 23:08 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
