CFD at vacuum
Old   August 3, 2007, 05:35
Default CFD at vacuum
Jiri Novak
Hi! Is it possible to use Fluent 6.3.26 for simulation of a gas flow at very low pressure (1-1000 Pa)? Are standard Navier-Stokes equations valid here? Does it exist any option for nearly vacuum flow in Fluent?
Old   August 9, 2007, 15:09
Default Re: CFD at vacuum
Jacques Kools
Hi Jiri,
the validity of the underlying physics used in CFD ( Navier Stokes equations)depends on the assumption that you can describe the gas as a continuum. This assumption typically breaks down if the length scale of gradients of the moments becomes comparable to the mean free path of the molecules ( described by Bird's breakdown parameter). For the case of Argon at room temperature, the mean free path is a few mm at 1Pa. Thus if you are interested in flow in a system with dimensions in the cm range, you will get solutions that are off. If you have a system with dimensions in the meter range, and small gradients, you might be ok. The type of errors you can get depends on the case, but a factor of two or more is not uncommon. For flows in the so-called transition regime and molecular regime, people have been using Monte Carlo techniques that work very well. Over here at In Silicio, we might be able to help you out. Send me a message at jacques.kools@insilicio.com if you want to discuss more.
I hope this is useful,
Jacques Kools
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 05:49
Since Last June John C. Chien Main CFD Forum 3 July 12, 1999 10:38
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
CFD Symposium (Call for Papers) Chris R. Kleijn Main CFD Forum 0 October 5, 1998 11:25
