gear pump modeling - dynamic mesh creating
Old   August 2, 2007, 11:48
Default gear pump modeling - dynamic mesh creating
Salvatore Bocolo
Hi everybody. It seems I got serious troubles. For my final dissertation, I have to develope a cfd simulation (using Fluent) to investigate how a gear pump works. The problem is that I'm an absolute beginner in this matter, and at the moment I don't know anybody who can really help me. My goal is to determine the velocity field, the pressure field and the instantaneous flow rate. I have a lot of material (books, articles, original Fluent tutorials and pdf), but no clear criteria about how to use or select it to carry out an effective/efficient job. Therefore, I will be grateful to anybody who can give me significant suggestions. Thank you in advance.
Old   August 2, 2007, 11:51
Default Re: gear pump modeling - dynamic mesh creating
Salvatore Bucolo
Only to retype correctly my surname (I hate mistyping...)
Old   August 2, 2007, 12:40
lee
log into user service site. if you don't have an account, just register online, and you will get one in 2 hours.
search key word pump. there is very detailed presentation of pump with dynamics mesh or so on.
Old   August 4, 2007, 09:10
msureshkumar
You have write udf for assigning motions to gear pump,mesh very finely and chek the flow. Pl. specify us about BC your are going to apply
Old   August 4, 2007, 22:00
Salvatore Bucolo
Sorry, what "udf" and "BC" stand for? Regarding motion, let's suppose n = 1500 rpm (costant). I'm talking about a common gear pump, with two identical spur gears, inlet and outlet ducts which simmetrically lead to and leave from the zone where the gears match. Moved fluid: oil. Thank you.
Old   August 8, 2007, 23:58
Bryan Godbolt
I am also having trouble with fluent. You mentioned in your original post that you had a lot of books on fluent. What are these books? I have not been able to find any fluent reference books.
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
Dynamic mesh is not getting updated. cardio FLUENT 1 May 20, 2014 09:41
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
C.G of Gear Pump Mustafa Ayad FLUENT 0 January 23, 2009 15:53
Dynamic mesh modeling Aditya FLUENT 1 January 21, 2009 16:44
