August 2, 2007, 06:55 |
How to model moisture within Fluent?
Does anybody know how to model moisture within fluent? I understand that the species transport model has to be implemented but it is not clear how to set up the model. I am looking at the humidity levels within a livestock trailer. I have modeled sheep as large blocks with a surface generating heat. I now need to set up a humidity model. Does anybody know how I would approach this problem? What type of boundary condition would I need to set? I assume it will simply be a wall with a base level of wetness but it is not clear to me. If anybody can help that would be much appreciated. All the best, Carlos. |
August 3, 2007, 21:04 |
re: How to model moisture within Fluent?
Hi
Use the Species model and define the properties of the "mixture species" in the materials window to have H2O and Air (H2O must be the top one). Choose "volume-wheighted" for density and "mass-weighted" for thermal conductivity and viscousity. Then specify the moisture mass fraction for inlets to the domain (this is the humidity ratio in the psycrometric chart). Specify a "constant" mass fraction value for the body of the sheep. |
August 7, 2007, 09:23 |
Thanks for your help AAA, this method appears to work fine - much appreciated. Just wondered if you had any idea of typical mass fractions of vapour for my boundary conditions?
When postprocessing I find that contour plots of relative humidity show values of 1000's of %! Clearly the humidity cannot exceed 100% at any given temperature. If you have any ideas please let me know. Best regards, Carlos. |
August 7, 2007, 18:03 |
Hi
Relative humidity must never exeed 100%. Have you heard about a Psychrometric chart? This chart is usually used by HVAC engineers (please find one) to find properties of air such as humidity ratio (mass fraction) by knowing the temperature and relative humidity, for example, among others. This will enable you to specify the mass fraction at the inlet and also predict the relative humidity at the outlet. Now if you don't know any HVAC enngineers, kindly send me the temperature and relative humidity you are using for the inlet boundary and I will give you the values for the mass fraction. Still, if you can find some one to show you the chart and explain it to you, this will be better. Kind Regards |
August 7, 2007, 19:26 |
Hi AAA,
Thats great, thanks for your advice. I think I may be having problems because I am specifying the humidity on the inlet AND the outlet, maybe I should leave the outlet alone this time! Your help is much appreciated. Thanks Carlos. |
August 7, 2007, 20:03 |
Hi
You still have to specify a "practical" mass fraction for moisture at the inlet to get a reasonable relative humidity for the domain. This is done by knowing the temperature and relative humidity at the inlet and finding the corresponding mass fraction from a Psychrometric chart. Otherwise, you might cross the 100% relative humidity line again. Regards |
August 7, 2007, 21:15 |
Thats brilliant!
Thanks, Carlos. |
October 25, 2009, 11:36 |
Rep Power: 17 |
Dear AAA,
i am trying to solve humidity transfer in enclosure, every where isolated except for ceiling..ceiling is cooled..but in Fluent i can see temperature gradient but there is no mass fraction of H2O gradient..it is almost same...i am trying to write UDF but, what is the source term? there is no generation of humidity in my room..how to include natural convection using bossinique model in simple species transport without reaction phenomenon.?please help me.. thank you |
October 2, 2015, 07:31 |
#9 |
Astio Lamar
Rep Power: 14 |
Sorry to bring this old topic up!
I f I have 20 oc for temperature, atmospheric pressure and 40% humidity, then from the Psychrometric chart I have the ration of 0.006. Should I specify this value for the H2o mass fraction in the inlet boundary condition? thanks. |
October 2, 2015, 09:38 |
#10 |
Lucky
Rep Power: 66 |
That is correct! Just make sure that's the dry bulb temperature and relative humidity.
October 4, 2015, 10:13 |
#11 |
Astio Lamar
Rep Power: 14 |
Hello and thanks for your swift reply.
I have simulate the humidity based on H2o mass fraction calculated from Psychrometric chart. the question now is how to post process the the result in CFD-post based. I try different method, but I cannot show the humidity for example at plane. Thanks in advance for your respond. |
October 4, 2015, 15:47 |
#12 |
Lucky
Rep Power: 66 |
What is your problem exactly? Are you unable to plot anything or are your missing "humidity" as a plottable variable? For example can you plot temperature on a plane?
If you need to calculate humidity: The relative humidity is given by the partial pressure of water to the saturated vapor pressure at the same (dry bulb) temperature. You can convert your mess fractions into mole fractions and calculate the partial pressure of water and then calculate the partial pressure at the same temperature. |
November 3, 2015, 01:19 |
#13 |
KEER AKSHAY TUSHAR
Rep Power: 11 |
what is mass fraction?
is it humidity ratio? what is the formula for mass fraction? |
November 9, 2015, 00:35 |
Air condensation over the Wings
#14 |
M Mohsin Iqbal
Location: National University Sciencies & Technology, Pakistan
Rep Power: 12 |
Hi
Sir i am carrying research on Air condensation over the wings. I am having problem for making settings in the Fluent. Kindly guide me how can i give prescribed humidity (say 65-70 %) to the computational domain. Thank You Looking Forward. |
November 9, 2015, 00:51 |
#15 | |
Lucky
Rep Power: 66 |
For water condensation, you need to do a multi-phase simulation. |
November 30, 2015, 03:28 |
#16 | |
M Mohsin Iqbal
Rep Power: 12 |
sir and simulation will be steady or transient ?????? i want to capture the fog cloud over the wings caused due to the condensation of humidity . looking forward |
August 19, 2017, 13:48 |
#17 |
Have a nice time!
Rep Power: 11 |
Hello, I want to get the values of the relative humidity for a simulation contains moisture (humid air), I think I have followed the steps that are shown here...I have the steps in the snapshots..Is this right or there is another thing that has to be further done?
Thanks |
August 19, 2017, 13:50 |
#18 |
Have a nice time!
Rep Power: 11 |
These are the rest of the snapshots
September 19, 2017, 02:18 |
#19 |
Vignesh Lakshmanan
Rep Power: 10 |
Dear Ahmed,
Your case seems to be fine as mentioned in this thread. Only thing you need to do, which I think, is that you need to enable source terms in the cell zone conditions. Thanks Vignesh |
January 27, 2018, 13:11 |
#20 |
Have a nice time!
Rep Power: 11 |
Thank you dear Vignesh
Seeking Macroscopic Particle Model in Fluent | bzhang7 | FLUENT | 3 | June 25, 2022 18:54 |
Fluent :- turbulence Model | prince_pahariaa | FLUENT | 9 | May 20, 2016 04:41 |
How to create a 3Ds Car Model importing to FLUENT? | spysunny | Main CFD Forum | 1 | January 11, 2012 00:40 |
Fluent 12 k-w SST turbulence model | DarrenC | FLUENT | 0 | December 13, 2009 09:33 |
Covert Star-CD model to FLUENT | Lam | Siemens | 6 | June 24, 2003 21:21 |
