How to model moisture within Fluent?
Like Tree15Likes
Old   April 25, 2020, 07:07
Morice is on a distinguished road
Originally Posted by vinerm View Post
There are three materials in a case with two components; two materials are the components themselves and one is their mixture. For the mixture, you might be using mass or volume weighted properties; use mass-weighted if density ratio is high. However, for individual components, you can still apply some of the material properties; not all though. So, you can go to Material Properties of Vapor and assign the properties as function of temperature. The material properties that you can assign for individual components depends on the options chosen for the mixture. If mixture property is based on some mixing law, then that particular property has to be given for individual component, otherwise, the property from the mixture is used. Boussinesq is not compatible with Species Transport.
Thank you so much for your responsee. Much appreciated.
I wanted to change the individual specific heat capacity of water vapour to a function of temperature. In you opinion, what is the most effecicient approach? expression or parameter? And if you do not mind, could you please write it out for me. It could provide a foundational insight into changing the properties of other materials that I want to undertake.
Thank you so much.
Morice is offline   Reply With Quote
Old   April 26, 2020, 16:48
Default Method
  #42
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The method is not important since all the methods are essentially same; whether you use expression or UDF or methods available within Fluent, result will be same if the dependence or equation is same. Fluent has inbuilt feature to apply specific heat as a function of temperature. You can choose one method and provide the coefficients. The coefficients are available on-line as well as within Fluent database.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 27, 2020, 03:14
thank you very much for your response. much appreciated
will look into it
Old   May 16, 2020, 07:59
Mahesh
mahesh1819 is on a distinguished road
Dear Vinerm, We have carried out using the transient analysis condition and as of now there are no errors. I thank you so much for your valuable inputs and support. Will let you know in case of any problem faced.
mahesh1819 is offline   Reply With Quote
Old   May 18, 2020, 23:36
Default k-e Buoyancy effects, Full or Only Turbulence Production?
  #45
Hey Vinerm,
Hope you are well.
Since Boussinesq is not compatible with Species Transport, in the k-e model, what buoyancy effects should be applied? Full or only turbulence production?
I was thinking it should be full?
What do you think?
Thanks, much appreciated
Old   May 19, 2020, 09:05
Default Buoyancy
  #46
vinerm's Avatar
Vinerm
Buoyancy is not include via turbulence models, rather via density of the substance. Use incompressible ideal gas or ideal gas. The options under turbulence models are sub-models that you may invoke if you want.
Regards,
Vinerm
Old   May 19, 2020, 09:28
Default incompressible ideal gas or ideal gas selection for density in modelling humidity
  #47
Buoyancy is not included via turbulence models, rather via density of the substance. Use incompressible ideal gas or ideal gas. The options under turbulence models are sub-models that you may invoke if you want.
Thanks for your response.
It is something I came across while doing research and I thought I would make an inquiry. I do understand. It seems I still have a long way to go in CFD.
For the density of the water vapour-dry air mixture, I used "volume-weighted" as per the suggestions in this thread.
Does using incompressible ideal gas or ideal gas give a more accurate solution?
Thanks, much appreciated.
Old   May 20, 2020, 09:51
Default Modelling RH and Temperature
  #48
Aykut
aefe is on a distinguished road
Hey there,
I'm trying to model a 2D box with an outlet.
The initial conditions of the air in the box are 45C and 95% RH, and the outlet is opening to an environment with a constant temperature and RH (Assume 20C and 50% RH). I want to see what will happen at the end of the given time.
I can predict that the hot and humid air will exit the box quickly at the beginning, and then the velocity of the exit air will slow down.
I have read all the written comments above, but could not manage to model it.
Is there anyone to help me with this model?
Thanks in advance!
aefe is offline   Reply With Quote
Old   May 20, 2020, 16:13
Default Natural Convection
  #49
vinerm's Avatar
Vinerm
If the box has only one opening, then the flow would be due to natural convection. That means, you need to enable gravity and the density should be modeled using either Boussinesq (only for single component fluid) or incompressible ideal gas or ideal gas.
Regards,
Vinerm
Old   May 21, 2020, 08:09
  #50
Aykut
Yes vinerm, there is just one opening like you said. Thank you for your reply.
First, I had modeled it exactly like that for temperature, and it worked.
Then I tried to solve the problem with the RH and I could not do it. Do you have any idea about it?
Old   May 21, 2020, 08:24
Default Relative Humidity Inclusion
  #51
vinerm's Avatar
Vinerm
How are you including RH? Via Species model? Essentially, you need to include the changes in the density due to the difference is species fraction in the mixture. Otherwise, it would behave like a homogeneous mixture and then the solution would be similar to what you got for the first case without RH.
Regards,
Vinerm
Old   May 21, 2020, 08:46
Aykut
Originally Posted by Ahmed Saeed Mansour View Post
Hello, I want to get the values of the relative humidity for a simulation contains moisture (humid air), I think I have followed the steps that are shown here...I have the steps in the snapshots..Is this right or there is another thing that has to be further done?
Thanks
I made it like Ahmed Saeed Mansour on August 19, 2017.
Yes I am using species model, I give my outlet 296.15K and 0.0096 mass ratio for h2o, which is the mass ratio for 23C and 55% RH.
Also I patch it as 323.15K and 0.0815 mass ratio for h2o, which is for 50C and 95% RH.
Old   May 21, 2020, 08:52
Default Density
  #53
vinerm's Avatar
Vinerm
What model are you using for mixture density?
Regards,
Vinerm
Old   May 21, 2020, 10:24
Default Setup Screenshots
  #54
Aykut
I uploaded the screenshots of my setup to this link if you would like to control
https://drive.google.com/drive/folde...Ma?usp=sharing
Regards
Old   May 21, 2020, 13:13
Default Density
  #55
Aykut
It is ideal gas by the way.
Old   May 22, 2020, 06:49
Default Cell Zones
  #56
vinerm's Avatar
Vinerm
You have only one cell zone while the scenario you're trying to simulate requires two. If you simulated your first case, the one with only temperature difference, using only one cell zone, then that's also incorrect. For a single cell zone, the flow is only due to pressure difference inside the cell zone and at the outlet boundary. The temperature and the specie mass fraction provided at the outlet do not affect the flow since those values are used by Fluent only during flow reversal. Those values do affect the diffusion near the boundary. You need to have two cell zones, one your regular cell zone and another one connected at the outlet of the first one. Then, initialize inner one with higher RH and outer one with lower RH.
aefe likes this.
Regards,
Vinerm
Old   May 18, 2023, 01:38
SURIYAGOWTHAM S
suiryagowtham is on a distinguished road
These are the rest of the snapshots
Thanks for the reference sir.
suiryagowtham is offline   Reply With Quote
Old   December 11, 2023, 01:37
Default Humidity
  #58
Mohammad
m.qodrati8@gmail.com is on a distinguished road
salam mohsen. vaght shoma bekheir. shoma tonestion havay martob ro modelsazi konin?salam mohsen. vaght shoma bekheir. shoma tonestion havay martob ro modelsazi konin?
m.qodrati8@gmail.com is offline   Reply With Quote
Seeking Macroscopic Particle Model in Fluent bzhang7 FLUENT 3 June 25, 2022 18:54
Fluent :- turbulence Model prince_pahariaa FLUENT 9 May 20, 2016 04:41
How to create a 3Ds Car Model importing to FLUENT? spysunny Main CFD Forum 1 January 11, 2012 00:40
Fluent 12 k-w SST turbulence model DarrenC FLUENT 0 December 13, 2009 09:33
Covert Star-CD model to FLUENT Lam Siemens 6 June 24, 2003 21:21
