July 21, 2007, 08:36 |
Heat fluxes seems the same direction ? :(
Hi, I want to solve an heat transfer problem that includes velocity inlet, pressure outlet, and tube surfaces. The cool air enters from velocity inlet then passes between hot tube bundle surfaces and the problem why the heat flux from velocity inlet and pressure outlet seems the same direction(negative). Has anyone have any idea? Thanks..
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
solver radiative and convective heat fluxes in CFD-Post | user | CFX | 3 | August 3, 2010 09:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
