problem with multiphase flow
Old   July 18, 2007, 21:15
Default problem with multiphase flow
sri
Hi
I am running a case where 2phases are injected near inlet at the same velocities,with turbulent k-epsilon model turned on.This case is working fine with single phase and when I switch to multi phase flow,I am having problems with convergence. I tried the same multiphase flow case with laminar model also. It is not working.
Appreciate your help in this regard.
Thanks Sri
Old   July 20, 2007, 14:47
Default Re: problem with multiphase flow
bashu
what are the densities of the two phases and waht multiphase model are you using?
Old   July 20, 2007, 20:17
sri
Air and liquid are the two phases.I am using Eulerian model
Old   July 23, 2007, 12:20
bashu
You have to use transient for Eulerian and your IC should be physically meaningful (maybe a system at rest) . Start with small time step. Hope these help.
Old   July 24, 2007, 07:56
Engr.Arif khan
Dear Sri try k-epsilon model for multiphase flow, first of all reduce continuity underrelaxation factor to 0.1 or 0.01, and Vf to 0.3, when 10s of convergence comes then adjust your underrelaxation of contiuity to 0.2 and of vf to 0.5. thanks and Regards Engr.Arif
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 19:30
multiphase flow ,phoenics user forum ismail Phoenics 0 October 23, 2008 20:26
CFX for multiphase flow problem NITIN DEWANGAN CFX 6 August 11, 2008 18:24
Multiphase multicomponent masstransfer and heat transfer problem rajeevrkris OpenFOAM Running, Solving & CFD 0 February 6, 2008 04:21
Converge problem for multiphase flow Jen FLUENT 2 September 8, 2005 09:47
