Create an UDF function for defining a zone ...
Old   July 18, 2007, 15:19
Default Create an UDF function for defining a zone ...
CFDNewbie
Hello. I need to create an UDF function for defining a zone from the cells of the domain, the cells will be selected in function of a particular variable associated with the cell center (in my case this the rms of the statical pressure).
This problem is impractical to be defined in GAMBIT because the cells from which I will create the zone aren't know in advance.
If anyone have an example or a piece of code how do that I will appreciate.
Thanks.
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
UDF for Species Mass Fraction Gradient *IN SPECIFIC ZONE * -- e.g. along axis of sym. ksiegs2 Fluent UDF and Scheme Programming 0 February 27, 2011 13:55
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
UDF parse error at profile function line Wiggy Fluent UDF and Scheme Programming 1 July 27, 2009 16:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
