July 18, 2007, 13:25 |
Gambit Cleanup
I have 3 connected real volumes in GAMBIT. I use the Geometry Cleanup tool to connect duplicated vertices, edges and surfaces. After I do that the 3 volumes become virtual volumes and I cannot convert them to real, GAMBIT says that there is some other virtual lower geometry, but there isn't any. Because the volumes are now virtual I cannot perform any volume splitting which I need to proceed with the meshing. How to clean up the geometry and keep it real? Thanks |
July 18, 2007, 16:17 |
Re: Gambit Cleanup
Use Gambit 2.4 (just released) or delete the newly cleaned volume and leave lower topology. Then rebuild volumes from lower real entities by stitching.
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
GAMBIT: Hangup on cleanup small face | smillerhh | FLUENT | 0 | October 9, 2006 02:30 |
3-D Mesh Check in Gambit..... | SHR | FLUENT | 4 | March 25, 2003 03:10 |
