to draw tech plot using fluent results(case& data)
Old   July 18, 2007, 14:13
Default to draw tech plot using fluent results(case& data)
madhuri
hi Iam madhuri,i would like to know how to draw techplot using flient case and data files. iam trying to show the swirl flow in the pipe by a 3-dimensional view of the axial radial and tangential velocities on a surface. can any one give me an idea to do this
Thanks
Old   July 18, 2007, 14:21
Default Re: to draw tech plot using fluent results(case& d
sujith
you can export the fluent results to tech plot through file-export-techplot option....
but im not sure about the 3d capabilities of tecplot
Old   July 18, 2007, 14:43
tarandeep
hi madhuri i v techplot 10 .just import the files in techplot using the option under file menu
Fluent: XY plot from file Ianto FLUENT 7 October 13, 2023 16:29
OpenFoam to Fluent data conversion Problem vemps OpenFOAM 1 August 8, 2011 03:30
how to compare unsteady state problem results from FLUENT with Experimental data? cuddaloreselvam FLUENT 0 July 10, 2011 09:25
recording data from the XY plot Karan Main CFD Forum 0 February 1, 2009 19:47
Problem of import fluent data to ilight fieldview seasoul FLUENT 3 September 9, 2008 23:36
