Boundary conditions at certain points
Old   July 16, 2007, 05:27
Default Boundary conditions at certain points
Maria
I want to calculate the heat transfer in a solid material, a 3D-model that has the shape of a thick bowl. I know the temperature on the outer surface and want to calculate the temperature on the inner surface, from measurements I also know the temperature at a number of points inside the material and the heat flow from the outer wall (this could be considered as an inverse heat transfer problem). I want to use these measured values as boundary conditions, can I apply boundary conditions to certain points?
It is possible to use these points to calculate isotherms, then maybe I could use the isotherms as walls with constant temperature, if that makes the problem easier?
Old   July 16, 2007, 08:19
Default Re: Boundary conditions at certain points
Joe
If you set the (known) temperature on the outer wall and set a reasonable estimate for the heat transfer coefficient for the internal surface you should get reasonable results.
You can then use your internal temperature measurements and outer wall flux for validation purposes.
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 09:59
