Macro Trouble -Winows Explorer Crashes with Macro |
July 13, 2007, 02:18 |
Hello All,
[Windows Vista 64] I was origionally using a macro for saving the data of an XY Plot, but since there is an explorer window that opens during the save comand it so happens that Fluent often crashed. I would like to take the following macro (.msh file) and create a series of commands under the Solve -> Execute Commands. I have a feeling that this method will stop the windows explorer from crashing. Macro: (cx-macro-define '((pttemp . "(cx-gui-do cx-set-integer-entry \"Execute Commands*IntegerEntry1(Defined Commands)\" 4)\n (cx-gui-do cx-activate-item \"MenuBar*PlotMenu*XY Plot...\")\n (cx-gui-do cx-set-list-selections \"Solution XY Plot*Frame9*List9(Surfaces)\" '( 0 11))\n (cx-gui-do cx-activate-item \"Solution XY Plot*Frame9*List9(Surfaces)\")\n (cx-gui-do cx-set-toggle-button \"Solution XY Plot*Frame1(Options)*ToggleBox1(Options)*CheckButt on4(Write to File)\" #f)\n (cx-gui-do cx-activate-item \"Solution XY Plot*Frame1(Options)*ToggleBox1(Options)*CheckButt on4(Write to File)\")\n (cx-gui-do cx-activate-item \"Solution XY Plot*PanelButtons*PushButton1(OK)\")\n (cx-gui-do cx-set-text-entry \"Select File*Text\" \"%t.txt\")\n (cx-gui-do cx-activate-item \"Select File*OK\")\n (cx-gui-do cx-activate-item \"Solution XY Plot*PanelButtons*PushButton2(Cancel)\")\n") )) Thanks in advance for you kind help, Martin |
July 25, 2007, 05:18 |
Re: Macro Trouble -Winows Explorer Crashes with Ma
Well it seems natural, but I seem to answer my own question on this forum. Nevertheless, here is the solution. Under Solve -> Execute Commands i have enabled the following commands:
Command-1 1 Time Step /dis sw 1 Command-2 1 Time Step /plot solution temperature y Command-3 1 Time Step /plot plot yes %t.txt n n n temperature (0 11) Please note that: dis= display sw= set-window (0 11)= defined points that I have setup for fluent to observe This was not an intuitive process to put this code together. -Martin |
