VOF plus Solidification/melting model
Old   July 13, 2007, 00:04
Default VOF plus Solidification/melting model
kql
hello everybody,
I use VOF and Solidification/melting model to solve phase changing material encapusulated in a spheric container opened to the air. considering the gravity field, natural convection will occur in the melting material, the solid phase will move down to the bottom, and the material volume expansion causing the air overflow throught the outlet. i patch a region of 85% phase changing material the air is the primary phase. the boudary condition is pressure-outlet. but the result is not correct. because after a short iterate the air diffuse into the phase change material. the curve of monitoring liquid fraction of solidification/melting is not the phase change material but include the air as the liquid phase. because the material didn't melt during the short time.
my question is:
1) do i need to define a interface between the two phase
2)should i consider the surface tension between the two phase
3)define/operating coditions/ reference pressure location ,which is the suitable value, at the bottom,at the outlet or at the center? because the air reversely flow into the container
the refer to the fluent help, there is an example about water and air in a revolving container. there is not need to extra define the interface.
Old   July 16, 2007, 05:18
kql
does anybody help me?
Old   January 14, 2014, 12:30
Mahboobe Mahdavi
Mahboobe365 is on a distinguished road
Have you found the solution? would you please help me?
Mahboobe365 is offline   Reply With Quote
Old   April 29, 2014, 17:50
thermal energy is on a distinguished road
dear friends,
does anyone have a solution ? we need to help eachother. good works friends
thermal energy is offline   Reply With Quote
VOF Model or Mixture Model mems21 FLUENT 2 March 9, 2010 11:37
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 23:00
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 10:57
help needed for vof model yan FLUENT 3 December 16, 2005 02:17
Moving mesh or VOF? Giovanni Main CFD Forum 16 September 24, 2001 09:25
