anyone having experience with THREAD_T0(t) ...
Old   July 12, 2007, 06:20
Default anyone having experience with THREAD_T0(t) ...
Kumud
Anyone having experience with THREAD_T0(t) please help me in solving this problem.
Everytime, I hook my UDF with this macro, the fluent give following error message: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
I am using the compile method for library building. My UDF is as mentioned below:
#include "udf.h" # define wall_id 3
DEFINE_EXECUTE_AT_END(my_domain) { face_t f;
cell_t c,c0;
Thread *t,*t0;
Domain *d;
real temp_adj=0;
real temp_grad=0;
real temp_wall=0;
d=Get_Domain(1);
t=Lookup_Thread(d,wall_id);
begin_f_loop(f,t)
t0=THREAD_T0(t);
c0=F_C0(f,t);
temp_adj=C_T(c0,t0);
printf("the cell temp is %f",temp_adj);
temp_wall=F_T(f,t);
temp_grad=C_T_G(c0,t0)[1];
printf("The temp gradient is %f", temp_grad);
end_f_loop(f,t)
Look forward to hear your suggetsions.
Regards Kumud
Old   July 12, 2007, 12:14
Default Re: anyone having experience with THREAD_T0(t) ...
jasond
This is just a quick thought - have you set the "expert" option to keep the gradients? I know for velocity gradients you'll have problems using C_U_G without making sure the gradients are kept.
Good luck.
Jason
Old   July 13, 2007, 04:05
Kumud
Thanks a lot..
Its working well after I set the expert options.
Also do u have experience in working with Macros like
TEMPERAURE_WALL(t), HEAT_FLUX_WALL(t)
defined in f_wall.h
Regards Kumud
Old   July 13, 2007, 12:22
jasond
Not in particular, but it looks like they tell you if you have that wall condition or not. But that is just what it looks like, and it doesn't appear to be documented anywhere - I would try it out.
Jason
Tired of employers focus on commercial code experience Steven P. Lounge 21 May 14, 2014 10:43
Experience implementing vorticity confinement tas38 Main CFD Forum 0 August 18, 2010 15:00
My experience Installing Elmer (Open Source Multi physics programme) on Linux Ahmed Main CFD Forum 3 August 10, 2010 14:42
Experience with accordionEngineMesh class chbenz OpenFOAM Running, Solving & CFD 2 June 5, 2009 06:08
Site devoted to private experience of application Dr. A.Ivanov Phoenics 6 November 28, 2002 05:05
