Convergence problem in SUPERSONIC FLOW
Old   July 7, 2007, 12:16
Default Convergence problem in SUPERSONIC FLOW
sridhar
I am solving the flow in cavity for supersonic flows. I find the following problems: 1. The solution doesnot converge .(I gave a convergence criteria of 0.0001) 2. In case of shocks where should I use UNSTEADY computation and where should I use STEADY computation. 3. finally, What are the most imporatnt things to look into when using when simulating supersonic flow . THANKS A LOT SRIDHAr
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Supersonic flow abishek FLUENT 3 July 28, 2008 07:07
Supersonic flow past a wedge with counter flow Mahesh Bailakanavar FLUENT 0 February 14, 2008 01:21
Problem with Convergence at high flow rates Syed Siemens 1 April 10, 2007 16:18
Convergence Problem Supersonic Flow Laval Nozzle Tobias CFX 3 December 7, 2005 02:23
