GAMBIT - warn about geometric tolerance
Old   July 6, 2007, 17:32
Default GAMBIT - warn about geometric tolerance
CFDNewbie
I have a problem with meshing an airfoil in GAMBIT, I use a very fine mesh of order 1e-06 at the wall for obtaining an y+ = 1. The error :
WARN: Mesh size on face.2 is smaller than the geometric tolerance. For an accurate mesh use larger mesh sizes and/or create geometry at a larger scale.
Thanks for your help.
Old   July 7, 2007, 00:49
Default Re: GAMBIT - warn about geometric tolerance
AJ
Could you model the geometry in mm or smaller dimensions or change the tolerance?
Old   July 7, 2007, 10:48
CfdNewbie
I could try using mm ... it should work with a 1e-03 smallest cell height. Thanks.
Errors during exporting from Gambit to Fluent redrum FLUENT 3 August 6, 2014 23:40
[GAMBIT] gambit global geometric tolerance alireza2475 ANSYS Meshing & Geometry 1 July 19, 2010 02:23
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 13:39
Tolerance in GAMBIT Help!!!!!! Lottar FLUENT 0 October 6, 2008 15:03
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
