Question concerning VOF
Old   July 5, 2007, 08:47
Default Question concerning VOF
Flora
Hallo, I am trying to simulate a 3D case in which two phase(water and air)are counter-current, namely they come into the calculation region in counter directions. What I am interested in are the free surface between the two phase. In my case the thickness of water is very thin, hereby surface tension can not be ingored and the grid should be very fine. On the other hand, in order to decrease the calculation time, the length for calculation is not enough. That means I'd like to induce a full-developed friction between the two phases to observe the influence of the friction. Now I am wondering whether i can induce the friction into VOF model? I have tried it as a momentum source in UDF but failed. Could somebody help me to check it?
# include "udf.h"
# define rho_g 1.225 # define rho_l 997.
# define Min_VOF 1.e-06 # define Max_VOF 0.999999
# define friction 0.44 # define d 0.001
DEFINE_SOURCE(x_Momentom_source,c,t,ds,eqn) {
real x[ND_ND];
real source,con;
real wvof;
real area,rho;
Thread **pt=THREAD_SUB_THREAD(t,1);
source =0.0;
C_CENTROID(x,c,t);
wvof = C_VOF(c,pt[1]);
if ((wvof>Min_VOF)&&(wvof<Max_VOF))
area = C_VOF(c,pt[1])*(1-C_VOF(c,pt[1]))/d;
rho = rho_g*(1-C_VOF(c,pt[1]))+rho_l*C_VOF(c,pt[1]);
con = friction*rho*area;
source = -con * fabs(C_U(c,t))*C_U(c,t);
ds[eqn] = -2.*con*fabs(C_U(c,t));
else
ds[eqn]=0.0;
return source;
/*I adopt C_U(c,t) to substitute slip velocity between the two phase, it is right?*/
Best regards Flora
Old   July 8, 2007, 07:29
Default Re: Question concerning VOF
Flora
Is there anybody who is familar to VOF model? Thanks a lot
Old   July 9, 2007, 10:50
Flora
Please discuss it with me. I am puzzled! Thank you very much!
about VOF and evaporation mengyue1 FLUENT 5 April 7, 2015 20:08
Question:Considerations about the evaporation in VOF dokeun FLUENT 10 February 24, 2011 21:47
Fluid - void VOF ic2010 OpenFOAM 0 April 26, 2010 05:23
vof + hydrostatic pressure ariorus FLUENT 0 August 7, 2009 11:57
One Question on VOF Model Colin FLUENT 2 October 24, 2004 10:38
