July 3, 2007, 16:24 |
.cas settings copy
is it possible to copy boundary conditions, solver settings, models, fluid properties,etc. (in other words all settings), from one case to a new one which is the same as before but has finer mesh? Thanks |
July 3, 2007, 19:44 |
Re: .cas settings copy
use
file write-bc "fname.bc" to write and read back with file read-bc "fname.bc" |
July 3, 2007, 19:56 |
alternatively you can prepare journal to start the case and read your courser mesh
July 15, 2007, 18:04 |
You can also use interpolate feature to import your data from a coarse to a fine mesh to avoid having to reinitialise a solution and start from a closer solution.
Settings in Solver Control | Roland R | CFX | 1 | October 12, 2011 07:44 |
thermoBaffleProperties object settings | calim_cfd | OpenFOAM | 0 | October 4, 2011 11:17 |
copy mesh settings | ACER | CFX | 1 | May 7, 2011 08:44 |
Can I make a copy of a patch mesh and move it? | bigphil | OpenFOAM Programming & Development | 0 | October 13, 2010 11:29 |
someproblem about the copy the .cas file | ztdep | FLUENT | 2 | October 19, 2005 09:00 |
