plotting streamlines
Old   July 2, 2007, 12:35
Default plotting streamlines
taran
hi all plz help me to plot streamlines over a circular cylinder
Old   July 2, 2007, 15:18
Default Re: plotting streamlines
Glenn
To plot streamlines emmitted from any surface... from the main GUI window DISPLAY --> Pathlines --> (select options). You can also create "oil flow" results for a surface from same location (see "Oil flow" toggle button, top, left. (Suggestion: set step soize smaller than default...it can change results.)
Old   July 2, 2007, 16:43
taran
Hi Glenn
thanks for the reply
i got your point , i have tried this out and I have two problems with this method 1. My problem is based on laminar flow over 2 d cylinder so i dont want the pathlines emitted from any surface rather they should flow over the surface of cylinder . With this method i am getting pathlines emitted from the cylinder itself which should not happen .
2. I want to plot streamlines specificaly although these are same for steady flow (pathlines n streamlines) but is there any other way to actually plot streamlines in fluent
i hope you understnd my problems
Plotting Streamlines Maciej Matyka Main CFD Forum 13 August 14, 2013 19:00
plotting streamlines in fluent Usman FLUENT 0 August 25, 2008 19:14
plotting streamlines taran FLUENT 0 July 2, 2007 09:50
Plotting Streamlines James Date Main CFD Forum 13 March 15, 2000 16:42
STAR-CD, moving grid and streamlines Mohamed GUEROUACHE Main CFD Forum 1 September 13, 1999 14:33
