July 1, 2007, 16:37 |
Flow over a cylinder
Hi all I plotted the xy plot for Cp for a 2d cylinder at a low reynolds number of 500 with laminar flow model .the plot of Cp is not coming symmetrical for both the upper and lower surfaces while it should come exactly symmetrical .Please explain this anamoly in my plot?
July 1, 2007, 18:20 |
Re: Flow over a cylinder
Check if your model and mesh is symmetric...
Follow this example from Fluent if this helps... http://flowlab.fluent.com/exercise/pdfs/cylinder.pdf |
July 2, 2007, 16:43 |
Hi AJ
thanks for the reply I checked the link but the graph of Cp given in this also shows anamolous result as you may check the graph is not symmetrical for upper and lower surfaces of cylinder which it should be. |
July 16, 2007, 02:24 |
as far as I know.
above Re=40 there will be a vortex shedding behind the cylinder and this can cause the flow to be assymetric. |
July 17, 2007, 16:15 |
yes i agree with you but even if theres vortex shedding then it should show its effect in the Cp contours which i am not getting . Moreover dont you think that the shedding should still result in symmetry because of the symmetrical geometry . I am not sure about the results therefore need more light on the topic.
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 12:47 |
1 Was FSI for a flow over a cylinder | vmlxb6 | CFX | 17 | May 16, 2011 03:29 |
Moving a Cylinder in cross flow after solving Dynamics equations of motion | maruthamuthu_venkatraman | OpenFOAM | 1 | November 19, 2009 14:55 |
Flow over a flat plate & Flow over a cylinder | cfdxue | Main CFD Forum | 0 | November 27, 2007 00:26 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 15:32 |
