Fluent 's basic equations
Old   June 30, 2007, 18:00
Default Fluent 's basic equations
taran
Hi friends
i have just started using the fluent . Can anybody tell me what equations the software uses in calculating flow past bodies and what is the meaning of pressure outlet (i mean to say that what are the conditions which are imposed when we use the boundary condition as pressure outlet)
and is there a gud book of fluent which can explain actually the physics and processes behind the software so that we can use it efficiently
thanks in advance!!
Old   July 1, 2007, 08:13
Default Re: Fluent 's basic equations
Muhammad Usman Qureshi
Please see the article 'Using the solver' in Fluent's documentation.
and 'Pressure outelt boundary conditions ' under 'Boundary conditions' . It says '' At pressure outlets, FLUENT uses the boundary condition pressure you input as the static pressure of the fluid at the outlet plane, , and extrapolates all other conditions from the interior of the domain. '' Please see Fluents documentation for your relevant problem. You can also contact Fluents academic help support for more help.
Old   July 1, 2007, 09:19
taran
Thank you sir for the reply .Please tell me from where we can find fluent documentation
Old   July 1, 2007, 15:22
hi, usually it comes with the software or you can simply type 'fluent documentation' in google.
Old   July 3, 2007, 09:15
Phil
The book 'Computational methods for fluid dynamics' by someone called something like ...Ferzier is in my opinion the best general cfd book. It has all the equations etc and then you can reference to it if you write them down.
This is of course as a supplement to the documentation which has everything you could need but can be a nightmare when you can't locate something easily.
The documentation can be gotten from the fluent website or you could download a copy using something like emule - as far as I know this isn't illegal but you should check first.
I expect though that all you need to do is go into the start menu then programs - fleuent.inc products - fluent documentation and click it!
Phil
Parallel fluent not using all processors specified Paul FLUENT 18 October 26, 2023 04:54
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 03:44
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
Fluent Basic Doubt Fluent learner FLUENT 16 May 30, 2008 05:09
how to solve non-dimensional equations in fluent warloque FLUENT 0 December 20, 2005 20:19
