mixture
Old   June 25, 2007, 10:57
Default mixture
alex
I need to run a simulation with a non-reacting gas. I know the species and the mass fractions of the mixture. I would like to know if it is correct to add the species I need from the fluid panel and save the mixture with the name I want, just not to overwrite the template, and then specify each specie and mixture properties. Can you give me the necessary advices to set up the case. Thanks in advance
Old   July 2, 2007, 14:45
Default Re: mixture
alex
Can anybody give me advices regarding the question mentioned in my previous message?
Thanks
mixture mass continuity eqn v.s. volumetric mixture continuity eqn kaifu ANSYS 0 June 9, 2011 09:42
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 09:14
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC richpaj OpenFOAM Bugs 2 October 9, 2008 23:14
Variable composition mixture .vs. reacting mixture Ting Wen CFX 0 January 7, 2008 07:04
Burning a CH4-H2 Mixture Jonathan Lemay CFX 2 November 12, 2007 18:01
