Turbulence : rectangular obstacle in a pipe
Old   June 25, 2007, 07:41
Default Turbulence : rectangular obstacle in a pipe
sam
Hi, I am solving a 2d axi-symmetric problem in a pipe with a rectangular obstacle at the centre. Flow is incompressible (air) with inlet velocity of 80 m/s. I am using Reynolds stress model (RSM) for turbulence. I see that turbulence kinetic energy and dissipation rate are high near the sharp edge of the obstacle and stretches in the flow direction ( above the region where flow separates from the wall of obstacle). however when i plot turbulent intensity i see maximum value occur in the wake region of obstacle and not in the region where maximum turbulent kinetic energy or dissipation rate occurs. can anybody help me interpret the results.. Thanks Sam
Old   June 25, 2007, 12:44
Default Re: Turbulence : rectangular obstacle in a pipe
tom
turbulent intensity is the ratio between tke and mean flow velocity. the mean velocity should be lower in the wake...
Old   June 26, 2007, 00:53
sam
I am sorry, it was turbulent viscosity not turbulent intensity. Sam
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 05:04
Turbulence model for Transient Pipe Flow Modeling Brian FLUENT 0 June 7, 2002 13:15
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 05:24
