Simulate mixing of two different flows in FLUENT
Old   June 23, 2007, 04:18
Default Simulate mixing of two different flows in FLUENT
Masood
hi
i have to simulate mixing of flows. one stream of steam with high moisture content in a steam of low moisture content. How it should be done in FLUENT. Plz help !!
Old   June 25, 2007, 12:46
Default Re: Simulate mixing of two different flows in FLUE
bashu
if these are both similar streams, you can use species to define mixture and the paramter needed is the diffusivity.
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
How to simulate a dynamically loaded journal bearing with Fluent? okiro FLUENT 0 April 7, 2010 22:16
How to simulate ice-on-pipe flow by Fluent zb FLUENT 0 April 8, 2002 23:41
ability of fluent to predict scalar fields in reacting flows ? Mounir Main CFD Forum 1 January 21, 1999 11:08
