Particle Injection Distribution
Old   June 19, 2007, 18:12
Default Particle Injection Distribution
t-student
Hi, I'm using fluent to do some particle tracking in a 3-d model. I am injecting particles from a surface. Any idea how I can make the particles distribution totally random along the surface with different particles diameters? thanks a lot!
Old   June 20, 2007, 00:12
Default Re: Particle Injection Distribution
thandavan
Hi use some kind particle size distribution function. rosin rammler is available in fluent. u can make ur own also
Thandavan
Old   June 20, 2007, 01:08
t-student
I understand I can use Rosin-Rammler with the parameters dbar and n, but I was wondering if I select surface injection with Rosin-Rammler, how these different diameters will be distributed among the nodes in the surface? Let's say I have a circle as the surface of injection. The diameters will be ditributed randomely inside the circle or it will be a uniform distribution?
Thanks a lot!
Old   June 20, 2007, 10:20
Allan Walsh
The best way for you to answer the questions would be try it out. The distribution will be uniform based on some range of parameters - i.e. position, velocity, diameter. For something more exotic, you would have to write your particle generating routine.
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Particle velocity - Injection With Line Weighting Danuta CFX 0 October 10, 2007 07:21
how to make particle size distribution adma CFX 0 January 10, 2006 16:57
DPM injection with RR distribution dan FLUENT 2 November 1, 2005 10:29
Particle Size Distribution with R-R fails? HP FLUENT 6 May 19, 2005 07:35
