June 18, 2007, 14:31 |
meshing in gambit,help pls!!
Hi i have a problem about mrshing in gambit.my geometry is rather copmlicated and i couldnt explain about it by writing,but i think my problem is acommon problem,anyway if any one have some exprience about meshing in gambit please help me . i recived belloe error: Volume v_volume.20 cannot be meshed because two sets of source faces which form natural starts for the projections could not be found.Best regards Amir
June 18, 2007, 20:36 |
Re: meshing in gambit,help pls!!
Hey Amir,
It seams that you have two faces in the same place which are comfusing the meshing process. From the Geometry command botton, choose Faces and then choose Connect (second top button from the right). Choose the whole domain and apply. This will get rid of any unwanted faces. Meshing should be smooth now. All the best |
June 19, 2007, 12:16 |
Dear Ahmad tankx alot foryour attenton, i do your guidance but i have same problem yet. Best Amir
June 19, 2007, 12:50 |
Hi Amir,
It seams that you are trying to use the Cooper option under Hex/wedge to mesh a volume. If so, try meshing one face, and then, for sources, choose the meshed face and the one opposite to it. Good luck Ahmad |
June 19, 2007, 16:12 |
Dear Ahmad i do it , but... if you agree , i send my geomtery for you. Best Regards Amir
June 19, 2007, 16:42 |
June 20, 2007, 01:26 |
Hi Are you using Cooper meshing scheme??? Did you mesh the lower geometry perfectly or are you just applying default options. I hope geometry is 3D as you have stated it is complex. how did you create it?send some more details about the error. bye ms
June 21, 2007, 05:53 |
Dear manoj s tank you very much for your attention, i use cooper , and change defaults .but as i said i can not explaint it ,but brifly i can say it is a part of junction of two vessel.but i can send its picture for you ,if you agree. Best Amir
April 2, 2013, 18:19 |
#9 |
Sujan
Rep Power: 13 |
Dear Amir
How did you solve this problem of "two sets of source faces which form natural starts for the projections could not be found" |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 06:22 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 12:03 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 06:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 12:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 12:08 |
