Problems with flat plate and NACA 0012 Lift/Force
Old   June 18, 2007, 11:02
Default Problems with flat plate and NACA 0012 Lift/Force
Harly
I'm trying to compare Fluent, OpenFOAM and Theory regarding flat plate and the airfoil NACA 0012 and my problem is, that my cases deliver inconsistent and both solvers wrong solutions.
My question is now, has someone tried to do the same and had success? - and what configuration did you use to get the proper solution?
I can send over my casefiles, if someone likes.
I would be very happy if someone could send me a testcase, which delivers right solutions (as I said important would be the solver configuration).
I'm using the the Prandt'l Theory for the flat plate ( cl = 2*Pi*angleofattack) and xfoil for the NACA 0012.
Hope you can help me.
If someone likes to help me with the OpenFOAM problem as well, that would be great.
Thank You Harly
Flat Plate Drag & Lift Joe Main CFD Forum 3 October 24, 2008 15:17
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 11:25
