properties of gas flow in channels
Old   June 18, 2007, 03:46
Default properties of gas flow in channels
romio
I want to modelling the flow and heat transfer of gases in microchannel which considered as incompressible flow.My question is what is the type of properties most be specify to the fluid esspecially density of (air or any gas) is it constant or ideal gas or incompressible ideal gas or what. Waiting for answer
with thanks
Old   June 28, 2007, 15:30
Default Re: properties of gas flow in channels
Mohammed
Dear! Can you please explain the steps for me to use fluent software program to model the foam flow and foam bursting? Best regards Mohammed
gas liquid flow Yuqing Feng CFX 0 May 4, 2004 22:26
ideal gas law in turbulent flow Achim Siemens 0 March 26, 2003 15:38
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
flow in gas turbine Abdul Hafid Main CFD Forum 1 September 14, 1998 10:39
