Lower topology
Old   June 16, 2007, 17:03
Default Lower topology
prem
I have a simple model which has three rectangles.I meshed them individually and tried to link them which is a necessary case.When I do so I always get an error saying cannt be meshed because of lower topology is inconsistently linked.Please help me how to resolve this.
Thanku, prem
Old   June 16, 2007, 18:15
Default Re: Lower topology
Phil
prem,
When linking faces for periodic boundaries or edges for anything I:
1) clear all meshes from the faces or edges 2) link them making sure I have the correct directions(reverse orientation) 3) mesh 1 then watch it being copied over the way I expected, if not I relink them more carefully then try again
Also all lower topology(rectangles,etc) to be linked must all have the same number of edges, vertices, faces, etc. But they don't actually need to be the same size.
So you need to copy all extra vertices on any rectangles to all the others to make them identical.
By doing these things you should get the hang of it pretty quick.
Phil
Old   June 18, 2007, 20:59
Ahmad
Hey Prem,
It seams that you have two edges/faces in the same place. To solve this problem, in the geometry command button, choose edges/faces, and use the CONNECT option (second one from the top right under faces)to get rid of any unwanted (repeated) faces in the domain. Select the whole domain AT ONCE. You can perform this step with the mesh on. A messege should appear if you have this problem.
Regards
Topology change and zone modification WiWo OpenFOAM 0 July 7, 2010 05:35
[ICEM] Building topology command script files Anorky ANSYS Meshing & Geometry 8 January 11, 2010 08:25
ICEM topology Igor-a CFX 0 July 24, 2008 08:05
Topology SAM FLUENT 2 October 13, 2004 01:01
Creation of an Inegral lower topology surface using Gambit 1.0.3 Remesh K FLUENT 1 June 26, 2000 03:58
