June 16, 2007, 03:43 |
improving a result??!!plz help!!
hi, to improve a result,i've tried to refine the mesh and to minimise the residual but i still need a better one!!what solving parameter can i modify?? thanks
June 16, 2007, 06:20 |
Re: improving a result??!!plz help!!
Donia, please check your Courent number for your specific grid and time step, this should help to get better results, Tomasz
June 16, 2007, 06:37 |
thanks Tomasz,but what do you mean by courent number?
June 16, 2007, 07:10 |
Courant number is kind of stability criteria for CFD computation - you can find decription in any CFD book
June 16, 2007, 07:11 |
Donia, look here: http://www.mech.uq.edu.au/courses/me...der-relaxation
June 16, 2007, 07:31 |
thanks a lot Tomasz!!
Improving Mesh - deleting cells | sErik | OpenFOAM | 6 | August 3, 2010 10:28 |
Improving convergence ? | Gearb0x | FLUENT | 1 | February 23, 2010 03:09 |
[mesh manipulation] Improving a mesh with OF utilities | bigred | OpenFOAM Meshing & Mesh Conversion | 5 | October 13, 2009 14:28 |
Improving mesh resolution | Vidya Raja | FLUENT | 1 | October 13, 2005 14:52 |
Improving resolution of the mesh | Vidya Raja | Main CFD Forum | 0 | October 13, 2005 12:14 |
