reynold number on inlet
Old   June 15, 2007, 05:14
Default reynold number on inlet
Fayyaz Hussain
Please can any body tell me
" could we give the reynold number on the velocity inlet"
fayyaz
Old   June 15, 2007, 10:03
Default Re: reynold number on inlet
Phil
Fayyaz,
You can define the turbulence intensity at the inlet which can be calculated from the Reynolds number. Look up boundary conditions/inlets in the user guide to get the equation for this and the hydraulic diameter which you will also input. This is just the diameter of the inlet.
You should select turbulence specification method as 'intensity and hydraulic diameter' at the velocity inlet window, then input your calculated numbers.
As far as I know this is the only way to do it but you could write a UDF to allow you to use any variable. The UDF would be written to use an equation to convert any value to the required format.
Phil
Old   June 18, 2007, 13:24
Fayyaz Hussain
thank you very much phil
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
