convergence problem
Old   June 13, 2007, 19:07
Default convergence problem
alexandre
Hi everyone, I'm trying to solve 3D turbulent flow around building model. But I have a problem with the convergence of continuity, k and epsilon equations. I need some help. Can someone point me in the right direction to resolve this problem? Thanks for your help
Old   June 13, 2007, 22:34
Default Re: convergence problem
Tomasz Bednarz
please check whether your Courant number is correct for the grid and timestep you are using, this should help to stabilize the convergency
Old   June 14, 2007, 15:31
alexandre
Hi Tomasz, thanks for ur help. The problem is that I'm using segregate solver and I can't control the courant number to stabilize my flow. I'm wondering if the use of time steady to solve the problem is the cause of the instability. Because my flow is very turbulent (Re= 22000) and may be the solver can't stabilize the flow.
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
