Require help in "Merging Grid Zones"
Old   June 13, 2007, 11:25
Default Require help in "Merging Grid Zones"
Nitesh Goyal
Hello all!
I request this community members to please help me in solving this case file.
I have a mesh file of an automotive engine which I have to simulate in Fluent and Rad-therm.
I intend to merge certain volume zones into single zone to obtain a surface which I have to use for post-processing. To prevent solution from getting affected with possible non-conformality which may occur due to merging, I feel its neccesary to perform simulations with the modified mesh.
Please suggest if there is a way which provides the feasibility of either:
1. Merging all the zones below certain boundary for eg: y=1.
OR
2. It would be best if you someone can suggest a way by which I can slect the desired zones in the Graphical User Interface.
Kindly suggest me a possible procedure either in Gambit or Fluent for the same.
Look forward for a kind reply from your side.
Nitesh.
grid check failed due to the merged zones biksham FLUENT 0 February 20, 2008 23:31
help with grid zones csertoi_aurel FLUENT 0 February 4, 2005 13:46
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 09:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 17:43
