Why Re is different for external and internal flow
Old   June 12, 2007, 23:46
Default Why Re is different for external and internal flow
john
We know that Reynold's no is different for internal flow and external flow? I wonder why does it happen? Is it the charecteristic length, which is different in both and so Re is different in both?
Old   June 13, 2007, 06:36
Default Re: Why Re is different for external and internal
laurent
Reynolds number depends on velocity magnitude and viscosity. If the length is different with the same flow rate (and same fluid) the Reynolds is different.
Old   June 13, 2007, 12:10
A A S
I am not sure what you are asking. The Re is defined the same for every flow. I think what you are asking is why the Re for transition is different for external versus internal flow?
Old   June 14, 2007, 04:53
laurent
Me too... What do you mean exactly by internal and external flow ?
Advice on turbulence model for complex internal flow JPBodner Main CFD Forum 1 September 3, 2011 04:07
Modeling internal and external flow for a nozzle smschnob Main CFD Forum 1 November 11, 2010 18:12
Internal flow simulation Kishore FLUENT 8 June 6, 2007 13:17
internal flow and external flow ? Pathway0320 FLUENT 1 November 17, 2006 04:37
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
