combustion in fluent..help
Old   June 11, 2007, 02:09
Default combustion in fluent..help
ssj
hi guys,
i am running co-air case in fluent using eddy-dissipation model.but it is not showing any increase in temp. does u have any idea how to initialize in fluent??.
adavace thanks
Old   June 11, 2007, 13:54
Default Re: combustion in fluent..help
AAS
You may need to patch a high temperature to initiate combustion. You could also try patching combustion products. A combination of the two is also possible.
coal combustion in fluent ramakant FLUENT 1 April 29, 2014 10:40
Limitation of Fluent (Combustion Modeling) Arun FLUENT 5 September 20, 2012 07:09
Combustion with FLUENT Rossc FLUENT 14 May 27, 2010 13:26
Combustion SImulation in Fluent santhosh1987 FLUENT 1 May 14, 2010 17:03
Fluent error in periodic PDF combustion cases?? George FLUENT 2 March 8, 2004 17:45
