Mass Flow Rate!!!
Old   June 7, 2007, 04:31
Default Mass Flow Rate!!!
haiduc
Hi everybody,
Is it true that The Mass Flow Rate from a small volumen to a bigger volumen has always be positive.
But the realised result of my calculation is negativ. Although the absolute value are the same in comparison with an other calculation.
How now? or is it a problem of setting/definition?
thanks Hai Duc
Old   June 7, 2007, 11:08
Default Re: Mass Flow Rate!!!
A A S
It could be because the outward normal is in the opposite direction of the normal velocity component resulting in a negative flux calculation (dot product of Vnorm and area vector in calculating mass flow across the boundary.)
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 10:58
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 21:33
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 03:42
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 08:17
mass flow rate error Masood FLUENT 0 May 22, 2005 01:32
